Rogue S automatic transmission to Tiptronic version.
DaTo
Car: BMW M5 e39.
Hi,
I have a few questions about Rogue transmission.
As i know, basicly the transmission is same, but how can i add my Rogue S tiptronic option?
Will it work if i change just "gear changer", i mean "PRND" (sorry for my bad english, i cannot explain differently).
Thank you for your help.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
DaTo wrote:Hi,
nope, not that easy. you will need the modules and programming. the computers tell the hydraulic system how many millimeters to increase or decrease in diameter in order to achieve the desired gear ratio.
DaTo
Car: BMW M5 e39.
ImStricken wrote:
DaTo wrote:Hi,
I have second Rogue SL that i have disintegrated. The car crashed and i used its parts for other cars.
I have every single part transmission, engine, everything.
So, what will i need? Just modules of SL Rogue?
Or old (S Rogue) module can be reprogrammed to Tiptronic?
ImStricken06
2016 Kia Sorento
from the top of my head: transmission ecu, shifter, (possibly main/engine ecu), clock-spring, etc.
DaTo
Car: BMW M5 e39.
ImStricken wrote:from the top of my head: transmission ecu, shifter, (possibly main/engine ecu), clock-spring, etc.
So, its hard work. :(
What about Keyless go? Is it also hard to take all keylessgo equipment from my crashed Rogue SL to new S?
ImStricken06
2016 Kia Sorento
DaTo wrote:What about Keyless go? Is it also hard to take all keylessgo equipment from my crashed Rogue SL to new S?
the whole ignition system, alarm system, antenna's, door receivers, push button door handles, modules, etc.
rdub2k4
Car: 2012 Nissan Rogue SE
2011 Mitsubishi Lancer GTS
Sad the tiptronic isn't just plug n play. I know on the Lancers it is :(
ImStricken06
2016 Kia Sorento
rdub2k4 wrote:Sad the tiptronic isn't just plug n play. I know on the Lancers it is :(
was the car sold with a feature that could be added on? if so - then all the wires and modules are already installed and ready to be used. mercedes does that too(other components other than tiptronic).
some companies dont waste the money and only make a certain model either have it or not - and not waste money wiring up basic models to have it, and then never recoup the money from those sold without the added feature.
rdub2k4
Yeah they did. I even have the HID harness tucked away and the headlight leveling switch tucked away and I don't have the OEM HID's in the Lancer. I was hoping Nissan would do something similar where the plugs would be tucked away, and just need the tiptronic shifter assembly in order to plug it in.
Sad times :(
ImStricken06
2016 Kia Sorento
rdub2k4 wrote:Yeah they did. I even have the HID harness tucked away and the headlight leveling switch tucked away and I don't have the OEM HID's in the Lancer. I was hoping Nissan would do something similar where the plugs would be tucked away, and just need the tiptronic shifter assembly in order to plug it in.
Sad times :(
idiots & schemers. lol
DaTo
Car: BMW M5 e39.
Sad times :(
I was thinking same too. :(
I thought that changing shifter will help this but i'm sad too.
Return to “Rogue Forum”
