Golfer »
https://forums.nicoclub.com/golfer-u198985.html
Sun Feb 19, 2012 3:58 pm
Need help guys....my 2008 Rogue S is 4 years old, and therefore needs new tires. Taking this chance to upgrade rims as well. I found (and already bought) a set of 2009 Nissan Maxima rims. Specs are 18"x8" offset +50. The tire fitment chart provided by EggNogg shows that I should use 225/55-R18. Will the +50 offset be a problem? If so, will using 5mm or 10mm spacers solve possible rubbing? Any possible adverse effects on using this set-up?
I'll appreciate hearing all pros and cons on this issue.
