kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Mon Mar 14, 2011 9:00 am
I bought a set for my Rogue off of ebay (great sale price I stumbled on) a couple years ago, I installed them myself easily and I think they look really great. They are a bit of a maintenance concern however, where I live we get severe winters with a ton of salt sand and gravel that really takes a toll on these things. It all buffs out if you buy good quality stainless but if you run your hand over the surface of mine near the front and rear wheels, they don't feel smooth anymore from all the sand blasting. Not a big deal but I do use chrome polish on them quite often.
The best part is installation was very easy, I did it myself and and the install hardware was very heavy duty and solid with brackets extending to the middle of the frame at the rear of the vehicle, I wouldn't hesitate to put a 400 lb person on one of those steps, they're very well mounted and secured. There is one spot right at the vertical pinch weld where the instructions called for a hole to be drilled, I really thought this was overkill as the other brackets were so numerous and heavy duty that I didn't feel it was necessary. In the end I did drill the two holes and add that final mount point but man it was hard going, even with carbide tip drill bit that steel was incredibly tough to drill through (just a small hole, I think it was about a 1/4").
