Rogue Jarhead »
https://forums.nicoclub.com/rogue-jarhead-u216599.html
Thu Sep 13, 2018 3:56 am
Likely just the ac drain. You could double check by shutting the ac off for a short drive, long enough to make sure any residual water has drained out and see if it still leaves a puddle when you arrive at your destination.
Or you could just physically examine the puddle water is clear non oily, every other leaking substance from a vehicle has some degree of color and oiliness.
