then can you at least cover up the key groove part and show me how the blade is connect to the remote in the inside??? please~~~crayb wrote:The key blade is replaceable. My Infiniti G35 and Rogue key blades will fit into each others remotes. There is also a phillips head screw that I'll assume can be removed and the key blade can be removed/replaced (I didn't try it though).
No pic b/c I don't want a copy of my key floating around the internet.
Ray
Yes i know that, it can be programmed to work on other NISSAN/INF. I just wanted to know if the key blade is replaceable with another key bladecrayb wrote:That key is ONLY for Rogues NOT equipped with the intelligent key system (buttons on the door handles to prevent you from have to take key out of your pocket to unlock or turn the ignition.
Ray
Sorry for not being clear, on the key i posted the ebay link with...not the i-keycrayb wrote:On the I-key or the one you have the linked picture off?
Ray
can you post or send me pic???crayb wrote:I just took mine apart. The phillips head screw removes the blade from the key ring holder allowing for another blade to be swapped in.
In looking at the other pictures of the key on ebay I'd be willing to bet the phillips screw can be removed to change the blades if needed. No guarantees with that, just a guess.
Also if you didn't know, you can ask the seller a question on ebay.
Ray
that item # is for the i-key...crayb wrote:Ok I gave up on posting a pic!!
Look at ebay item number 280379851861, the silver ring holder can be removed when you remove the phillips screw.
Ray
