philipa_240sx wrote:Where is Pescakl1? He's the winter driving guru...
Hello, I am back!!! (from a business trip).
So, I am a snow guru now ? Doing stupid things in the snow usually don't qualify people as gurus at the end, but why not.
I pretty much agree with everything that has been said previously, especially the winter tires advice. But getting winter tires for one or two snow storms a year may be quite a expense.
Something that has not been asked to the OP: Did the snow were even on the road when the car moved?That reminds me when I had my Subaru Legacy (Subaru = ones of the best of snowy conditions): Everybody were going too slow to my opinion on the highway, so I decided to use the third line which was unplowed and barely used. The left front tire took a groove while the right one hit a plow a slush heavy snow, which instantly tried to spun me around. I believed I was at about 30 degrees spun when I was able to catch it back (thanks to the all wheel drive system, keep your foot down), and I decided to stop my idiocies and go back in the middle line with the others.
If one side of your car hits more snow than the other, it will be slowed down and makes the car turn around. That is what may be happened to you.
The AWD system of the Rogue is probably one of the best of the non-permanent ones (permanent ones: Subarus and I think the RAV4). As contrary as the others which takes too much time to kick in (= too late), the one on the Rogue works almost all the time: At the start, in curves, etc...
I thought it was like the other ones, that is why I bought a FWD, but if I had to do it again, I would probably take an AWD (but there was also some economic reasons for the FWD choice).
Also, check your tire pressures: If they are too high, you will lose some grip. You could them down to about 28-30 psi during snow storm to get better grip and more confidence, and then back up to 32-34 when there is no snow on the road.
