I would need to be able to measure out and test fit the kit. That requires someone locally, unfortunately...joshjv wrote:Are you only looking for guinea pigs in SoCal?? i'm in Mi.. I'd be interested in trying it out..
Thanks for the offer, but I won't know what to measure until I actually see a Rogue in person. I don't do those typical grounding kits that ground the engine to the shock tower (completely pointless).joshjv wrote:If u gave a list of measurements needed, I could help u out..
Hey joshjv... sounds like you're out of luck on the guinea pig angle. If you feel adventurous... you might get some ideas for a DIY project via this thread:joshjv wrote:Are you only looking for guinea pigs in SoCal?? i'm in Mi.. I'd be interested in trying it out..
He's not completely out of luck for the guinea pig option, just not for the initial measurements and test fitting.Elton Noway wrote:
zerothread?id=432882
