Rogue front differential?
rfa77
Car: 2011 Nissan Rogue
Ok, I'm a novice and all I seem to find are posts on how to change the rear differential fluid. Is there a front differential fluid that needs to be changed or does the rear take care of the whole system? Thanks.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
rfa77 wrote:Ok, I'm a novice and all I seem to find are posts on how to change the rear differential fluid. Is there a front differential fluid that needs to be changed or does the rear take care of the whole system? Thanks.
the front differential is actually an internal part of the front wheel drive transmission; like every front wheel drive vehicle
the only fluids in the drive train you need to drain is:
engine coolant
engine oil
CVT transmission fluid
transfer case fluid (gl4/5)
rear differential/carrier fluid.(gl4/5)
read this map i drew:
Return to “Rogue Forum”
