They're saying that since the headers delete the cat it will make the cars ecu have a b**** fit. I may just do a resonator delete and a 2.5 apexi world sport 2 muffler and see how that soundsBlack B15 wrote:Exhaust and mufflers has been done, and one or maybe two guys even did the dual exhaust.
The real question, at least the one that keeps coming up in my mind, is why has no one installed the header from the Sentra? After looking into this extensively, I am almost convinced it will bolt right up. No guarantees, but it is the same engine (2.5) with the same midpipe connection type and location. I am fairly certain not a single person has tried this yet. I was going to do it and I almost pulled the trigger but after going nuts on my previous vehicle wifey was kind of giving me "that" look. Might have to wait a little while before I can install one!
***EDIT: Even with the limitations of the CVT transmission, I don't think that small amount of HP is going to push the transmission too far. I can't imagine a header on this 2.5 engine giving more than maybe 5-7 hp. Also, if the dealer tries to decline repair for having a header on just say "Magnusson-Moss Warranty" act and see how their attitudes change.
Nah....a simple "ghetto sim" will do the trick. Not to mention you would still have your main cat, just not your precat. The precat is (or at least was) known to break-up on the QR25DE and in some instances get sucked back into the engine causing catastrophic failure.SlimSlammedRogue wrote:They're saying that since the headers delete the cat it will make the cars ecu have a b**** fit. I may just do a resonator delete and a 2.5 apexi world sport 2 muffler and see how that soundsBlack B15 wrote:Exhaust and mufflers has been done, and one or maybe two guys even did the dual exhaust.
I think the answer is quite simple - because it's a Rogue. It's not meant to be a performance vehicle. A header will change the sound but also most likely cause a loss in low-end torque which in a 4 cylinder daily driver is usually not what you want.Black B15 wrote:The real question, at least the one that keeps coming up in my mind, is why has no one installed the header from the Sentra?
Trev's post is dead-freaking-on. couldnt have said it better myself.TrevorK wrote:I think the answer is quite simple - because it's a Rogue. It's not meant to be a performance vehicle. A header will change the sound but also most likely cause a loss in low-end torque which in a 4 cylinder daily driver is usually not what you want.
A lot of modifications people seem to do here are all for visual purposes, which is great. But the engine modifications don't really have a noticeable payoff so it's really not worth the money.
If you're into modifying cars you have probably bought a Rogue so that you can focus on modifying your other toys. Not on modifying the Rogue. That's my opinion at least.
+1 If I want performance I drive the sports car instead. The Rogue isn't bad for a small, inexpensive 4 cylinder CUV but it's no match for a vehicle built from the ground up with performance in mind.TrevorK wrote:I think the answer is quite simple - because it's a Rogue.
While I understand, and even somewhat agree with your point, it is really all "in the eye of the beholder" so to speak.TrevorK wrote:I think the answer is quite simple - because it's a Rogue. It's not meant to be a performance vehicle. A header will change the sound but also most likely cause a loss in low-end torque which in a 4 cylinder daily driver is usually not what you want.Black B15 wrote:The real question, at least the one that keeps coming up in my mind, is why has no one installed the header from the Sentra?
Oh yeah, I agree...when I want to speed around I hop in one of any number of exotic sports cars that I own. Do I want to drive the Lambo or the Ferrari today? Hmmm. Maybe the Masserati. Ahhhh....the McLaren F1 will do!takeshi wrote:+1 If I want performance I drive the sports car instead. The Rogue isn't bad for a small, inexpensive 4 cylinder CUV but it's no match for a vehicle built from the ground up with performance in mind.TrevorK wrote:I think the answer is quite simple - because it's a Rogue.
Exactly. Plus I would be curious to see how those guys who have done any exhaust upgrades to the Rogue feel on the subject. I am fairly certain there were two guys who had done the dual exhaust with muffler upgrades and I seem to recall them both saying how it sounded pretty good.rdub2k4 wrote:Very true, however, the OP's Rogue isn't what you would call, stock.
