roguemaster wrote:HAS ANYONE INSTALLED THOSE BLUE XENEON HEADLIGHTS ON THEIR ROGUE?...........EASY TO INSTALL?
Interesting... The degree of difficulty installing aftermarket Xenons was never a consideration to me. I know I could do it. Personally... I had two other concerns that always stopped me short from doing it.
1) Theft What about theft? Is it still the issue it once was? By 2004 both dealers and insurance companies began warning consumers about the increased risk of theft and damage to their vehicles if they went with the Xenon headlight option. Reports of multiple thefts (attacks on the same vehicle) were commonplace by 2007. Car companies like Nissan even came out with aftermarket kits you could install to hamper the theft, making the removal more difficult. However, it only made matters worse because the thieves did not let the complexity of the removal slow them down. They simply starting using crowbars and cutting the main wiring harness leading to the headlights. In some European imports the headlight wiring harness is incorporated with the airbag system. Cut wiring harnesses activated the airbags resulting in repairs costing $10,000.
As late as 2007 insurance companies reported Xenon thefts were almost as common as wheel/rim and stereo thefts. NOTE: The bad guys only want the burners and ballasts, your headlight housing assembly is of no use to them. So... busting out your fancy plastic lenses or damaging your car and paint as they pry out your headlamp assemblies with a crowbar is of no concern to the crook.
2) Aftermarket Blue Xenons are illegal in the US
A consideration .... maybe even bigger than the risk of theft... Are they legal?
The last thing I need is to be pulled over and given a hefty ticket. First I'd have the expense of paying the fine... then I'd be out the money I paid for the headlamps since the ticket is also a warning to remove them. If you don't remove them get stopped by the cops again... then "Hold on to your shorts!" Even if you don't get pulled over and ticketed... many more people are dismayed everyday when they find their automobile Inspection Station fails their car for having aftermarket Xenons.
The following is a cut and past from Wiki:_________________________________________________
True xenon headlights are legal in all 50 states. True xenon lights are sometimes confused with "blue headlights". True xenon lights do give off a very slight, barely noticeable blue tint, but still appear white, which allows it to comply with the white colored headlamp requirement in all 50 states. Many fake or pseudo xenon lights are marketed to unsuspecting buyers. These lights are in fact illegal to put on a public roadway. They are legal to put on your vehicle as long as you don't put the vehicle on the highway. As of 2008 the only factory legal xenon lights come on BMW, Mercedes, and some other high end European sedans. The aftermarket xenon conversion kits being sold are not true xenon lights and are not legal. An easy way to tell if the lights are illegal is if they give off a very noticeable blue color when viewed looking toward the vehicle from outside of it.
In the US aftermarket conversion is illegal. Some countries have the law only for OEM (factory fitted) Xenon lights like UK. Other countries have no such law and you can do what ever you want._________________________________________________
FYI: I'll probably still do the conversion ... just thought you should be aware of all the possible ramifications.
