GermanRogue wrote:I imported my Rogue to Germany and the inspection office is telling me that I need to get yellow lenses for the blinkers. Does anyone have any suggestions for a source I can go to to acquire rear lenses with a yellow blinker??
Welcome to an uniform world... or how to prevent people to import cars from other continents (being playing these silly games for many years).North America is not better, don't worry, they are as bad as Europeans.
As for your problem, check with the inspector if this is OK for you to have a red lens as long as the blinker is orange at the end.
If this is OK, your solution is to get a yellow light behind the lens to get it orange/amber at the end. I wrote yellow, not amber or orange, just pure yellow, otherwise it will be too close to red and they won't see the change. It needs to be powerful because a lot of light will be lost(filtered) in the lens. Your best solution is LEDs as you will be sure they have only the yellow wave and not another one. That is what I planned to do my own as I want amber blinkers on my car (European background taste here).
If this is not OK, then basically you are screwed as they are no European equivalent of this car as Philip showed you. Your best chance is if an aftermarket company decides to do a clear replica of our tail light, which is not the case as for now. You can also try the solution from Elton Noway but be careful as our tail lights are welded so you will have to dremel them opened as you cannot bake them up opened. It is not as easy as the headlights, you will have to do it slowly and carefully and find a way to close them up after (rubber butyl sealant with use of screws).
Good luck.
