ROFL @ broken output shafts...
Booztd 3
Car: 1990 Nissan 300ZX TT
http://videos.streetfire.net/v...7.htm
~2:40ish
Think im gonna make it on the next PINKS/NAPA Commercial?
FYI- Broke an output shaft....
Cjmartz2k
Car: Hunting for a '89 GTR now
s*** man!! That's the R205 diff you did that too, huh? Wow. Any wheel hop?
gawdzilla
Car: none
never wash your car again! Rich pushed it and told you to go to napa hahah. at least broken output shafts are better than those last 2 cars
Booztd 3
Cjmartz2k wrote:s*** man!! That's the R205 diff you did that too, huh? Wow. Any wheel hop?
Thats actually an R230.....it doesnt get any beefier than that....
I actually didnt move an inch on the line......hit the 2-step.....dump the clutch and BOOM
Carl H
impressive that you killed the ledgendary 6 bolt spread axle output shafts...
Booztd 3
Carl H wrote:impressive that you killed the ledgendary 6 bolt spread axle output shafts...
That actually makes two now......2 years ago I broke the passenger side...hehe
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
You know... I would have thought the bolts would shear off before that shattered....Damn engine gnomes...
Cjmartz2k
GTR different from the 300zx? I just upgraded to a GTR diff/axles/hubs with the 6 bolt spread pattern. Looked the same as yours, but maybe not.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
come on man! should have launched a lilttle lighter.
Carl H
gt-aaaaaahr final uses the same outputshafts and axles as the r230 out of the z32 tt.still an r200 carrier tho.
USMCgetsome
i forgot to add that I AM SOO PROUD OF YOU GETTING OUT THERE AND SHOWING THEM WHAT THAT Z32 CAN DO!
HowlerMonkey
Car: 1991 Infiniti M30 wi/ L28ET
I've seen that happen when the car's compression of the suspension or other suspension movement on another axis caused the wheel to touch the tires to the body and bind.
If you're putting down that kind of power and have the R230 though, I am pretty sure you've already checked out that possibility.
