Rod/Main Bearings
J240sx
Car: 89 240sx
I am doing a rebuild and am going to replace the rod and main bearings. I had the crank checked/balanced and it's fine. So do i just get the standard size bearings? The pistons I am going with are cp 86.5 and eagle rods.
JDizzle
Car: 1995 Nissan 240SX
If your crank has been check and is within spec then standard size. If you're going with OEM bearings you'll need to check the FSM as they have 3 or 4 different standard sized bearings.
J240sx
Car: 89 240sx
Thank you sir, i will probably just go with the acl bearings.
