boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Sun Sep 02, 2007 6:39 am
Let me ask all of you one question, have any of you ever experienced a stretched rod bolt on a CA18 rod? I don't know where this rod bolt thing started, but I guess it started like all the rest of the ridiculous rumors about the CA18DET such as the stock headgasket will blow past 15psi of boost or the CA18DET needs to be beefed-up after 300hp or the CA18DET has a weak bottom end, etc, etc. Your rod bolts are not your issue and you guys need to stop spending money in these silly little areas because of myths and rumors. Focus on a good engine management system and refresh the bearings, pumps and rings if you really want to get technical.
It's just killing me to see alot you new guys starting all kind of crazy threads about this and that when in all actuality most of you guys' projects will fail before you finish it and will end up being for sale on this same forum because most of you don't listen and wanna do things your way. Take heed to some of the advice that's being given to you by people who have been where you guys are trying to go. And for the record, I constantly 2-step my engine that contain some rods that I've had for 8 years and have not had to worry about any rod bolt garbage being cased on this forum. And if you do find a way to stretch one, it's probably because you over-torqued the damn things or just totally abused an already totally abused engine.
Dee
