Phat_Optimo »
https://forums.nicoclub.com/phat-optimo-u7876.html
Sat Sep 23, 2006 3:42 am
After the bolts have been removed theres 2 steps to reworking the big ends of the rod. 1st step it to shave a very small amount off the sufaces where the caps meets when they are bolted together. We use a cap cutter (special machine that cuts small amount of meatal where the cap meets the rod). Then you press the bolts in put the cap on and tq the rod w/ out a bearing. Then the rod has to be honed out (to OEM spec) on a rod machine. When you cut the caps it makes the big ends circle smaller. So a honing it out gets the big end perfectly round. This has nothing to do with the bearings. I did mine not too long ago.
