aftermarket bearings usually only come in a few sizes, because most people using after market bearings have machine work done on there engine. there crank journals are usually uniform size. if you are going to use aftermarket bearings i would have a machine shop mic and polish your crank to a uniform sizeSlipstream wrote:You can use either stock or aftermarket. Just be sure you have the clearances correct.
