well right now i dont plan on taking past the factory redline, im just putting bearings in the stock motor, the old ones looked a little worn so i figured before i put the motor back in my car i might as well do bearings, nobody around my area has got a full season at the track out of their sr swaps because they develop rod knock, so i figured new bearings, a good inspection of the oil system and a greddy oil pan may help me get a little more life out of mine before i have to do a full build.codyace wrote: OEM works everytime for me. Use the FSM and the numbers on the crank/rods/mains to determine what size you need. I like going a size looser myself in every hole if you're going with higher RPM stuff.
Mazworx:auto alchemist wrote:
redtop91, where did you get you calico coated bearings? i may have to check those out too
these were on stock SR's, theres no way of telling what happened to them before they were imported but it seems like if your doing anything but going in a straight line they blow, around here the guys that drag dont have many problems with them, its all the guys that auto cross, road coarse or drift their cars that have all the problems.Hijacker wrote:Sounds to me it's more like your friends slapped a junkyard motor into their car and expected it to pull 12s with no prep work.
A properly maintained SR will make good reliable power.
when the SR was in my car the first time i was using royal purple 5w-30, and a greddy oil filter, i was thinking about going 20w-50 but i havent found any yet thats synthetic, and im not sure if 20w-50 would be too much for the SR or not.codyace wrote:
Sounds like alot of your friends had tiredmotors and or don't use the proper oil/maintenance.
Best of luck...if you have any questions just ask
i noticed it says these bearings have more clearance, do plan on running thicker oil?
Mobil 1 makes that exact oil. I use that in my 240 for both daily driving, and track use, with no issue.auto alchemist wrote:
