rod bearings
andromeda
what is the best rod bearing to get? and where? thank ya (91 240sx SR20DET)
LostAndFound
Car: 89 SOHC 240sx
id go with OEM or ACL
eazye2000
Car: S13 KA-DET
Just going to put out my personal experience. But I used Clevite for my KA-Turbo engine. No problems as of yet. Clevite Rod and Main bearings.. Matter of fact, I've always used Clevite. Even on my old V-8's.
I've heard ACL is pretty good. And you can get them 'Calico' coated with some sort of lube for initial break in.
But then again, OEM is pretty darned good.
andromeda
ok cool. anyone used these? http://www.worksevo.com/store/...d=322
C-Los83
Car: 1996 NISSAN 240SX SE
from what I know Cosworth is at least a reputable name. Their products get used on race engines quite a bit. Shouldn't be any problems with these either.
andromeda
just ended up getting some clevite bearings overnighted. cant wait on standard shipping. gotta get this sucker on the road!
Hijacker
Car: '92 240sx Convertible
'94 F-150
Personally I prefer OE as Nissan has different grades for thickness of bearings. When you buy aftermarket, you rarely get to choose the picky thicknesses. However, that's all the thickness options Nissan gives you are. Picky. From what I've been told, the difference in thickness from thickest grade to thinnest grade is miniscule. I'm just OCD when it comes to motors, so I tend to try to stick as close to what the factory had in their.
Another thing to note about coated bearings is that as they see use, the coatings will wear off. When they do, the bearing does in essence become thinner, which can lead to problems down the road, but that's only if your bearing was already on the thin side to begin with. If you go for a tighter tollerance out of the gate, once the coating wears off, you shouldn't have any problem.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Are the OEM SR bearings F770?
andromeda
Hijacker wrote:Personally I prefer OE as Nissan has different grades for thickness of bearings. When you buy aftermarket, you rarely get to choose the picky thicknesses. However, that's all the thickness options Nissan gives you are. Picky. From what I've been told, the difference in thickness from thickest grade to thinnest grade is miniscule. I'm just OCD when it comes to motors, so I tend to try to stick as close to what the factory had in their.
thanks for the insight man. i will put it to use
Hijacker
'94 F-150
redtop91 wrote:Are the OEM SR bearings F770?
That's a good question. I'll find out.
