rod bearings?
240crawler
Car: 1991 240sx
I spun my #3 rod bearing about 2 weeks ago. Honed the journal with 600 grit coated in fuel, and put all new bearings in. Cranked up last night, and what do I hear? Rod knock once again.
I have decided to pull the engine and put everything brand-new inside. I cannot, however, find connecting rods. My local Nissan dealer cannot even order them. Where can I find some rods?
Dammitboy
Car: 92' Nissan 240
Dammitboy
Car: 92' Nissan 240
You live under a rock? There's quite a few rod makers now. Try eagle rods for starters.
Also, try & find the original cause of your knocking.
torque2go
Car: 90 240sx
you could of measured your journals or plastigauged them to see what size bearings you would need.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
so when you bought bearings what did you buy? did you buy the correct grade bearings, or just std size in non nissan bearings?
and i hope you plastigaged them too. sorry man, it really sucks to have to go through this twice, but i think you may have missed some stuff by being over-eager
240crawler
Car: 1991 240sx
yes, I used the plastigauge. I was in spec for oil clearance, so I do not know what caused the bearing to re-spin. I bought Clevite std, but since I am redoing, I have ordered new bearing from local nissan dealer. I had to get grade 2 for 1,2, and 4; and a 0.08 upsize for #3. I cannot find rods, I must live under a rock. My internet acess is limited to 20 minutes/wk. I do not order from internet anyways. If I cannot walk in and pay cash, I do not want it.
But some good came of this mishap. My old project is back on boil. I have the engine ready except for driver's side header and radiator. Here it comes....560sx!
Raxephon
Car: '04 RX8...for the moment...
VK56DE?
figment521
Car: 89 240sx
Take the crank and rods to a machine shop and have them re size the rods and check the crank to make sure is is not out of round.
