unless you're reusing your old rods, you won't be able to use the old bearings. there are two methods to getting the correct bearings for your motor. i don't know if you got a set of aftermarket rods or not, so the first option might or might not work. It's usually for OEM replacement rods.
Option 1:You'll need an SR FSM. You can find one at
http://www.zeroyon.com Next, find the section for engine internals in the mechanical section. In it, it explains how you can use the numbers stamped on the rods and the numbers stamped on your crank to determine what bearing to get. It has a table and everything so it will all be spelled out for you.
Option 2:Take it to a machine shop that does work on engines, tell them it's a Nissan SR20 motor and you'd like to have your aftermarket rods measured and have them figure what size bearing to use for each rod.
