Rod bearing clearance
tmann
Car: 1995 Nissan Altima
Hello all, I have to replace the rod bearings in my 95 altima (rod Knock). Can any body tell me the proper bearing clearance after they are torqued ? I'm using a piece of plastigage and I want to get it right the first time. Thanks.Tom
480sx
Car: 1996 Pearl White 240sx
Duddeeeeeee! FSM!
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
tmann wrote:Hello all, I have to replace the rod bearings in my 95 altima (rod Knock). Can any body tell me the proper bearing clearance after they are torqued ? I'm using a piece of plastigage and I want to get it right the first time. Thanks.Tom
What motor are you running?
mutiny
Car: 1989 240SX
95 altima is ka24de i think
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
If the motor is a KA24DE, then the rod bearing clearances are as follows:Standard: 0.010 - 0.035 mm (0.0004 - 0.0014 in)Limit: 0.09 mm (0.0035 in)
