NeverEnuff wrote:but y not use 13 in rims with low profile tires be realy ez to git them to spin would lower the car qwite a bit thow
This guy Stanbo at one of the drift meets i went to was running a significantly smaller overall tire diamiter. S13s alrealy ride close to the ground and the smaller diamiter wheels made it sit even lower. Needless to say, i had to help lift the car up off the floor jack after the wheels were put on :pface
Sure it works, but i think its worth it to practice with the correct tire diamiter so its the same weather your at the track or if you decide to slip in a quick drift in a empty parking lot on your way home from work. The 240 can drift really good with stock sized wheels, a stock motor, a LSD, and someone who puts in the practice time
