Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Dec 27, 2007 8:30 am
Check the cam lobes for worn spots that seem to be too focused. If there's too much force on one particular spot, I could see that potentially leading to a failure. Normally, the worn spot should be spread across the whole cam lobe.
Other than that, I'm at a bit of a loss as to what could be causing the breakage
