nzmoman »
https://forums.nicoclub.com/nzmoman-u41093.html
Sat Jun 17, 2006 9:11 am
ive never heard of an issue with rocker arms. and ilikemy240sx is right. if your rocker arms go you need to start searching for another head because something is seriously misaligned or coming way loose. rocker arms prevent float, float does not apply a ton of pressure because its caused by a high speed rotating mass, so if you have valves that are supplying pressure to rocker arms so much that it would cause damage by the time you found out your head would be in pieces because you would more than likely be experiencing some sort of internatl head damage before the RAS or the rocker arms gave out.
Modified by nzmoman at 1:44 PM 6/17/2006
