hmm.. i might have to go over everything. it seems to be leaking from the half moon side too. do you have to use a in/lbtorque wrench instead of a regular one? seems like the bigger one doesn't torque down that low. i just hand tighten them to "tight" since torque is so low.... im just afraid of snapping the bolt.compression wrote:they are east to put on. You need some grey silicon gasket maker, a gasket scraper, torque wrench, and the page from the Factory Service manual that shows the tightening order and torque values for the cam tower bolts.You need the gasket maker to re-seal the cam cover gasket around the half-circle shaped plugs.
It doesnt say on the link i put up in the earlier post but its very important to tighten the bolts to the right spec. I dont know off the top of my head but it can be found in the FSM. This is importantnismostate wrote: hmm.. i might have to go over everything. it seems to be leaking from the half moon side too. do you have to use a lb/in^3 torque wrench instead of a regular one? seems like the bigger one doesn't torque down that low. i just hand tighten them to "tight" since torque is so low.... im just afraid of snapping the bolt.
nismostate wrote:i know it's important but is it even possible to torque it down with a regular torque wrench? i used a regular torque wrench to torque the clutch plate down to 25ft/lb and it snapped the bolt. And yes, i know how to set a torque wrench. So again, do you use a inch/lb torque wrench to do it?
Huh? What are you talking about? The FSM even calls them rocker arms.93Niss240 wrote:I dont know y every1 calls them rocker arms (stoppers) even GReddy, HKS, Tomei, etc. They're really not even rocker arms in the SR20DET..... I guess its easier than calling them cam follower or finger follower stoppers :P
They are probably more oriented for racing like on a track where shifts may be at high RPM's and the RPM's are constantly higher than normal. Its not shocking that out of only 3 over rev situations nothing has happened.mynismo wrote:i revved up my old sr20det about 3 times missing a gear (all the way up to 9k --- no rev limiter). nothing ever flew off and i never had any problems. no ras's were installed.
