Rocker arm stopers
vboyq
Are there any instances where the stoppers are necessary or are they more of a precautionary type of thing. If not then in what instances would i possibly need them? THANX
BuudWeizErr
It's a good precautionary thing to have. If you miss a shift when you're racing, and have your engines RPM's go skyrocketing, they can protect you. However, they aren't "necessary."
Dori Dori
Car: Cars of course
It will help in the prevention of valve float...a RAS kit and some aftermarket valve springs should strengthen your valvetrain considerably. Something you should be concerned with when adding big power.
Phax
Car: Control dynamics
vboyq wrote:Are there any instances where the stoppers are necessary or are they more of a precautionary type of thing. If not then in what instances would i possibly need them? THANX
For the most part, it depends on how much power you want to make, and how often you're going to be taking the car near the redline. I'm a high revving junkie, so I went for the RAS because I figure that the extra insurance is necessary given the way I drive.
vboyq
I like to rev junkie too! but besides the point who makes good ones and how $$. Also if i have like say a rev limiter from a MSD Ignition then i really shouldn't have to worry right?
I H8 UR DSM
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
Just ask Pat about his SR..... missed a shift and did like 1k in damage to the head, pistons, ect. RAS is pretty cheep insurance IMHO.
PaulOrlando, FL
lagvoid
if you decided to add ras, what else would be good to do at the same time?
Dori Dori
Car: Cars of course
Valve springs and cams (if you want). The valve springs are another good preventive measure against valve float...and they are 'cheap' too.
Phax
lagvoid wrote:if you decided to add ras, what else would be good to do at the same time?
I'm doing valve springs at the same time, knowing that sometime in the future I'll be getting some aftermarket cams.
lagvoid
I'm not familiar with ras, I assume that its internal work right? If so, it may be a good time to build the engine up as well (if you have the cash).
matt240det
lagvoid wrote:I'm not familiar with ras, I assume that its internal work right? If so, it may be a good time to build the engine up as well (if you have the cash).
not really, you don't even have to take off the head to install ras, i think just the valve cover and cam squirters
lagvoid
thanks for the info.
Dori Dori
Car: Cars of course
http://web.tampabay.rr.com/enthalpy/180sx/
Look at the pics that say headfunxxx.jpg There are some with the RAS installed...just to give you guys a visual if you are not familiar with rockers...
Phax
Dori Dori wrote:http://web.tampabay.rr.com/enthalpy/180sx/
Dori,
Could you please email those pics to [email protected]?
Remove the NO SPAM from the above.
BuudWeizErr
http://www.forumpix.com/240sx/
Somewhere in my gallery, there are pics of us installing the Rocker Arm Stoppers. I have no idea what pic though.
Dori Dori
Car: Cars of course
Phax, I am confused at what you want me to do? That's not my website btw...
Phax
Dori Dori wrote:Phax, I am confused at what you want me to do? That's not my website btw...
I was wondering if you could email the pics to me, because I thought that it was your website. I got a copy of Acrobat though, and just downloaded the whole directory. Are yours the Tomei RAS? I just picked mine up at HKS today, and they don't look anywhere nearly as nice.
Nils
Car: road racing
I'm about to put in some HKS RAS on my car tonight.... any tips to give that would help me before I start?
Looks like a fairly straight forward install.
What about torque specs on the bolts holding down the RAS and also to re-tighten the valve cover back on?
tia,n
Nils
Car: road racing
nevermind.. it was an easy install.
n
