Rocker Arm Soup..... I miss my CA (sorta)
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
How this all happened Raced 2 bikes
I had to throw that last one in there for all my old CA18 buddies..... damn tin can motors.
PaulOrlando, FL
Hijacker
Car: '92 240sx Convertible
'94 F-150
dah! that sucks! how long she gonna be out of commision?
Movingviolation240
Getting a new one tomorrow at 9am as soon as Kenjuku gets into work. My GF is gonna pick it up and drive it over.
Should be to work ontime at noon :)
Paul
GTS4-R
Car: my feet
u got RAS? if not, would it have prevented that?
Movingviolation240
I have it, but it happens anyhow
Paul
Hijacker
'94 F-150
it looked like it split where the RAS made contact
Movingviolation240
The RAS isn't bent, dinged, or otherwise looking like it even had a workout. There was a little spot where you could tell somthing touched it, but it was hardly noticable (almost could have been put there when I installed it).
But I only broke 1 so maybe that's what saved the rest of my motor from coming appart.
I also found out that they run pretty good on only 3 cylinders, enough to drive like 60 miles at 80+mph anyhow. And it will still make 1 bar in that configuration, but it lags a lot worse.
Paul
Hijacker
'94 F-150
the rocker was probably just old and weak.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
did you get stiffer valve springs?
Movingviolation240
nope, step 1 cams and just the RAS. Scott at Secret Sercives seemes to think that that's acceptable. I missed a shift so I can't say that he's wrong, just my dumbness that did it.
Paul
Hijacker
'94 F-150
i dunno. missing a shift wouldn't stress a rocker like that. i think that it was just ready to go
ImportIntelligence
Car: Big turbo's :)
Man oh man, we have 2 motors in the shop now that look exactly like yours. Pesky rocker arms. The FSM says to replace these items as well as the rocker arm keepers aka valve shims. Nissan's fired for this design.
Onizuka
At least they built the bottom end right :D
Hijacker
'94 F-150
thankfully!
Movingviolation240
well, when I say 'miss a shift' I mean 8000+rpm 3rd to 2nd at about 100+mph.
Not good for long term use
Hijacker
'94 F-150
ok. that's different. i was thinking of closer to 6500
NeedCAforS13
Car: CA swapped S13 coupe
BWAHAHAHAHAHAHAHAHA! what are rocker arms... come on, really, I've never seen those;)?
I am gonna have to say read the sig, and remember the good old days! BTW, this is excellent for all the silly SR guys (both here and OrlandoForums) that think that RAS are the end all cure for Nissan's bad design. Come back to the dark side Paul! :firedevil
But in reality, this sucks man:(... if you need any nissan oem parts, call my cell saturday, and I'll get you your stuff! I hope its not too expensive to fix it...
BTW, gotta link this to the CA forums for ya:pface
Sean
Phax
Car: Control dynamics
Movingviolation240 wrote:nope, step 1 cams and just the RAS...Paul
How high did you rev the motor? Valve float sucks. I wrecked an L-series valve train a few years ago.
What's the lift on that cam?
Edit: Ouch... 8000+ before the downshift? Bro.... :(
Onizuka
NeedCAforS13 wrote:BWAHAHAHAHAHAHAHAHA! what are rocker arms... come on, really, I've never seen those;)?
Sean
Too bad nissan forgot to put a manly bottom end in the CA :D
My rocker arm stoppers sheild me from everything! Including stupid people named sean and all his CA cronies!
NeedCAforS13
lol matt... CA cronies attack!!! gotta kick 'em while he's down, otherwise I just don't stand a chance:pface
Sean
Hijacker
'94 F-150
funny how that works :)
Phax
Before this gets too out of hand, I have to stand up for my motor real quick. Paul downshifted at 8000 RPMs. 9 out of 10 KA-T's won't even spin to 8000RPMs. CA's will do it, but will they be generating the same amount of torque at that point as an SR?
One of sixteen arms broke. That's not bad, for stock valve springs and cams with more lift and duration than stock.
Paul, am I safe in assuming that SS removed the 7800RPM rev limiter? Do you always rev your motor that high? If so, I'm jealous... and can't wait to finish tuning mine.
NeedCAforS13
yeah obviously 400+HP SR owns my ~250HP CA... probably even on 3 cylinders... I'm not a huge SR20 or s14 fan, but I'd make an exception and take Paul's car!:boink
Sean
*edit* or your car too Phax... two of my favorite cars on NICO:bearchug
Onizuka
one of eight ;)
This is all in jest by the way guys, we all know that all Nissan motors totally kick arse so there is no point in bashing. :D
Hijacker
'94 F-150
yay! i can keep my car!
NeedCAforS13
J-Spec Tuner wrote:This is all in jest by the way guys, we all know that all Nissan motors totally kick arse so there is no point in bashing. :D
what he said ^ I completely respect the SR, its just not for me... every engine has its strong/weak points:)
Sean
Hijacker
'94 F-150
some engines have more weak points than others. take the CA for example -=ducks!=-
Nathan
Phax wrote: 9 out of 10 KA-T's won't even spin to 8000RPMs
Since were having fun in this thread I'll just have to say that the KA-T's wouldn't NEED to spin to 8000rpms, we've got the displacement to make up for our lack of revs AND we tend to have more low end torque :D Sorry about your rocker Paul, have a blast putting the new one in ;)
float_6969
yea, I've got my RAS for my CA on order....Oh wait...Hehehe. JK Paul, but good luck with it and hopefully you don't have to deal with that again!
Dori Dori
Car: Cars of course
RAS is to prevent valve float people. Rockers are still a suck *** design and can/will break from running at high rpms and/or tons of power.
