Rocker Arm shim question
Deadrodent
Car: 1992 240sx hatchback
Hey everyone, I recently pulled my head (head gasket blew on cylinder number 4) and am rebuilding the head but I can't seem to find one of my rocker arm shims...In fact, I stupidly didn't record which shim goes to which rocker arm so I'm going to have to reshim everything - which means I need to get a new set of shims right? Where can I get these - preferably locally (Bay area)? Can I use a sr20de's shims? I need to get my car running soon so help would be greatly appreciated! thanks in advance!
Hijacker
Car: '92 240sx Convertible
'94 F-150
The shim sets are identical to the DE.
boogerlovers
Car: 240sx coupe
dont you have to measure to get a new set of shims and guides...? i lost all of mine and im in the same situation as this person.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
i thin kthey are all 3 mm. we measured all of mine and i thin kthat is what they were
BuLLeTdrift
Car: 91 240sx fast baq
you think? dammit man, remember!
I dont have this problem, but it would be good to know. I know for sure all the shim guides are the same size across the board.
MMotorsports
Car: 1989 nissan 240sx with SR20DET
The shims are the same unless you have went with aftermarket cams or springs.
Deadrodent
there are two shims - one with slots on the top and ones that are completely flat - where do the slotted ones go and where do the flat ones go? i took the head apart in such a rush i forgot to remember these details (plus i was rebuilding a semi-truck engine at the time..)
i'm trying to slap the head back together as fast as possible as my car is hogging up shop space at my friends shop
MMotorsports
Hey to make it easier I am rebuilding a SR20DET right now and I will send you a pic to your email to avoid confusion alright.
Slideways^Jordan
Car: 1989 240sx Coupe-1991 240sx Hatch back
idahotuner wrote:i thin kthey are all 3 mm. we measured all of mine and i thin kthat is what they were
I know for sure that the stock guides and shims are all 3mm cuase remeber when you had your guide and shim incident in the parts cleaner i told you the guide and shims are 3mm.
lol
MMotorsports
Alright well I thought I would go ahead and say just incase if any else is wondering does not matter if you look from the left side or right side of the head the flat shim goes on the right valve.
Sabot
I know for sure that most of the shims are different sizes. I done plenty of SR's s13 and s14's maybe a couple were all almost the same size so I didn't had to order new shims. Just measure your shims and guide to be sure, the guides should be the same size but not all the shims are.
All the info is in the FSM
Modified by Sabot at 9:45 PM 1/11/2008
Slideways^Jordan
MMotorsports wrote:Alright well I thought I would go ahead and say just incase if any else is wondering does not matter if you look from the left side or right side of the head the flat shim goes on the right valve.
The Shim is the flat peice of metal= Valve on the Right.
The guide is the peice of metal with the slot in the middle of it= Valve on the Left.I Hope this helps you i made it real fast on MS PAint.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
lol
yea. that sucked. i know but i got them all back in and a huge acident was avoided. lol
Deadrodent
thanks for the help everyone! i'll be putting everything together tomorrow morning and i'll let you guys know how it turns out!
Deadrodent
ahhhh i'm missing a shim again! what year sentra should i get the shims from at the dealership??
Hijacker
'94 F-150
Any year that has an SR20 in it. I typically call in for a 97 model SE-R. Tell us if they tell you a 3.0mm shim doesn't exist. My JDM service manual has the shim thicknesses listed at like 2.8 and 3.2.
sr1000psi
How many shim /guide u need ? Cause i have extra for my back up motor.Let me know . Just Email me : [email protected]
Sr1000psi
sr1000psi
Will ship them for u today.
Good luck !
ThanksSr1000psi
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
well guys the maching shop guy didnt measure the shims very well. i h ave to pull my cams back out and measure all my shims to put them back in the right place. to get ride of the ticking in my head,
ILikeMy240sx
Car: SR Power
all the guides are the same height 3mm. (the ones with the slot)
Shims are the ones that have different sizes to adjust your rocker arm height position. (the flat ones)
The tolerance spec called out by the FSM is the difference in height between the guide and the shim is .001 inches.
I stopped posting on the forum for a while but I kindda got really disgusted by all the misinformation here.
GL to all.
BTW, .001 inches of height difference is AFTER being put on the valve stems.
So, after you put them on the valve tips, you use a dial indicator to measure the difference in height between the two and if its w/in .001 inches, you are good.
Modified by ILikeMy240sx at 5:23 PM 3/8/2008
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
damn dude. i liek it when you post because you have so much good info.
slik_s13
Car: 1990 nissan 240sx hatch back
very usefull info. im in the process of reshiming as it turns out.
