compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Sat Jun 22, 2013 9:16 am
First, you can't just replace the shim and guide. The guide is exactly 3mm and the valve that has the shim had to be measured in comparison to the hight of the guide and the proper shim size must be installed in order to keep the rocker level. Also if the cam beat up the rocker to where there's visible damage, it needs to be replaced. If the cam has visible damage it needs to be replaced ( and even if it's not damaged needs to be miced out and see if it's within spec) and finally, lifters in operation are under far more pressure than you can apply with your fingers. If that lifter Is suspect of Collapsing than just replace it with a new one and bleed it properly before install.
