I didn'ttenkawa_akito wrote:you will have to removed the oil baffle to make everything fit properly.
This is exactly what I did with my greddy RAS.quikdime wrote:I installed my tomei rocker arm stoppers without removing the baffle. You will have to remove a little material from the baffle plate. Everything will fit fine. I would not suggest removing the baffle as you may have a oil blow-by problem. Good luck.
