Rock-it Oil™ -1001 uses! lubricate, clean, degrease, protect
Rockit_Oil
Car: Infiniti FX45
http://RockitOil.com
What is Rock-it Oil™ Brand Technology?
Rock-it Oil is a revolutionary technology based product that Just Works! It is an amazing combination of proprietary formula which produces amazing results.
1,001 uses and some we haven't thought of yet!
Rock-it Oil's unique formula means it can be safely used in body repair shops without risking paintwork contamination. Body shop Friendly!
Here's just a fraction of the uses:
WHEELS
• Protect magnesium, powder coated, lacquered, alloy wheels from rust and chipping and blistering.
• Prevents water and moisture from penetrating the surface
• Wheels stay cleaner and are easier to clean
• Remove road tar
Maintenance & Restoration
• Can be used as an engine 'easy-start' spray - even on two-strokes.
• Will water-proof ignition leads and electrical systems
• It will clean corroded electrical contacts & relays
• Lubricate ratchets, rails, anchor chains, steering cables, hinges
• Will not only clean metals such as aluminum and stainless steel, it will also help prevent further marking when handled.
• Lubricates telescopic aerials without attracting more dirt.
Detailing, and Repairs
• Takes oxidation off paint.
• Seals off ignition and wiring.
• Removes chrome rust and surface pitting.
• Use on all metal, crankcases, shocks, chains, electrical connections, battery terminals,
• Leather seats and saddle bags to clean and waterproof
Available now at The Home Depot!
Facebook: http://www.facebook.com/userockitoil
Youtube: http://www.youtube.com/user/RockitOil
300ZXttZMAN
Welcome to NICO!!!
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Seems pretty handy, I could use a can
Just an FYI, guys - I bought some. I've been using it for about 2 months, and this stuff is the real deal. No sticky messy residue like WD40, and it seems to "crawl" way better...
It's already saved me some money. Used it to rehab a 50-year old ignition switch (plus, it took the corrosion right off the terminals), freed up an old antenna on the Bluebird, sprayed some on a piece of #000 steel wool and it TOTALLY removed rust and stains on an old set of wire wheels I was refurbishing. I used it on the tracks/rollers/chain for my garage door opener (WAY quieter) and our 8' tall sliding glass door, and it makes the door / hood / trunk hinge mechanisms on all our cars work a lot smoother.
Just go get some!
