rob bearing and pump replacing
codyharrelson
Car: Nissan 240sx with a rb20
my rb20det in my 1993 240sx hatch, lost oil pressure and i believe spun a bearing. What are the steps in replacing it on this car.
p.s. jarco sucks as, second engine and only had it for 2 days
Carl H
dude if you got the motor thru jarco and it died i HIGHLY doubt it is their fault.if you search you will find out that the rb20 is plagued by the short snout problem...however intial restart and what not are important.its easiest to just pull the motor out and replace the bearings that way, but inspect the oil drive snout and the pump for damage.
BoostFab
Car: S13cp, S13fb, S14z
replace the main bearigns while you're at it. your crank may need a repolishing...
lazyboi444
Car: 240sx Hatchback
Hey i know this is kinda off topic. But where can i get the plastic guages from to measure the bearing clearance?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
local machine shop or autoparts store. it's called plasti-gauge.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
however, I found that you at Autopart stores you really need to talk to someone who knows what your talking about b/c no one knew jack when I tried to source it for the first time.
Clevite 77 pasti-gauge is like $1 at AutoZone and they keep it behind the counter.
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
We have it at the napa store I work part time at too. Your going to have to pull your engine. Remove the crank. Buy a new oil pump most likely. Buy a crank collar and get that machiened on there. Buy a new set of main and rod bearings. Get the crank journals polished and posibly have to crank balanced too. It would be nice to have a factory service manuel to check the specs of everything else. Then you can make shure its going to be ok once you do fix the crank. I did all this even before my rb20 ever was started. The engine sat for a good 2 years im shure before i got it. My rb20 had around 40k on it everything was mint inside. But now when i drift it and have it tuned for 300whp it should hold together I hope.
Coolwhip
Vendor
same here with my 25.
Engine was fine when i got it, and next week will be 2 years and I have yet to run the engine in my car. Replacing all the vitals so when i do run some power I don't have to worry as much about those parts.
Pulling the motor to do the job is the only and best way. As well, check all the components when you tear her down so you can accurately source the problem and prevent future ones.
Good Luck and let us know how it all plays out.
