roaring sound and cracked rotor?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Tires make roaring sounds.
Jons_G35_sdn
Car: 2003 G35 sedan-no doggy door,91 240sx sold,04 subaru wrx stage 2
my car started making a roar type noise in the rear (sounds like passenger side rear) so i jacked her up and spun the wheel but got nothing, i did find a small crack on the rotor though, could this be it? Maybe the rotor is warped? My tires are pretty worn aswell (mainly that side the sound is comming from) could that be it?
Jons_G35_sdn
RED_DET wrote:Tires make roaring sounds.
so you think its the worn down tire? Its bad worn too like dang near slik, i would have bought some new ones already but the brand i need (same as front tres) dont make the 235/50/r17's i wanted so im just sticking to 225. When i get from work ill throw on the spare and see if the sounds persists.
RED_DET
Vendor
2011 Infiniti G37x
As tires wear out they become louder. If it is as described, I wouldn't be driving on it.
Jons_G35_sdn
ok i found the problem it wasnt the tires, it was the axle nut that came loose and had some rubbing going on with the brake asembly. Its all good now and it was actually the driver side.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
