Road noise
irsmart
I'm new to the G35, in my case a 2004 with only 17,000 miles on it. Can anyone advise what's causing a general road noise noticed especially under 15 MPH? Definitely not the squeal of brakes, more low-end "rumbling". Would seem to be more than tire noise (by the way, I'm running Michelin Pilot Sport). But what I've read elsewhere in other Forum entries perhaps I should look no further! Nor do I hear a mechanical grinding. But here too: maybe bearings going out?
soul_hfk
Car: 2010 G37xS---08 QX56
welcome to NICO.... post some pics of the new lady and 17k that great for a 04 but sorry i cant help wit the road noise
joe603
Car: 2014 Durango R/T
So speeds greater than 15mph you don't hear any noise? Could be suspension...need more info!
telcoman
irsmart wrote:I'm new to the G35, in my case a 2004 with only 17,000 miles on it. Can anyone advise what's causing a general road noise noticed especially under 15 MPH? Definitely not the squeal of brakes, more low-end "rumbling". Would seem to be more than tire noise (by the way, I'm running Michelin Pilot Sport). But what I've read elsewhere in other Forum entries perhaps I should look no further! Nor do I hear a mechanical grinding. But here too: maybe bearings going out?
If I were you I would look around for another 2004 G35 and test drive that one as a comparison. It sure sounds like a tire issue but perhaps you could temporarily swap out all four tires for a test drive? If the problem remains after a tire swap perhaps a visit to the dealer to get it checked out might be the next step?
Telcoman
chad1200
Car: 2004 G35 AT Sedan
is it continuously under 15mph or just after you start it? i know that ABS does a quick check when you first get goping after it sits for a while. for an 04 to only have 17k miles it must have sat for a while. tires might be warped a little. try a rotate. cheap!
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You are probably experiencing tire feathering and you hear the noise as it is more pronounced at lower speeds. Check the insides of your tires and see if you are getting feathering. There will be a high/low feeling when you rub your fingers across the tread.
infinititech1
its your tires...inside feather wear. very common problem... had alot of complaints about this
RED_DET
Vendor
2011 Infiniti G37x
whats the alignment spec for the toe that is supposedly fixing this problem? max toe in?
infinititech1
toe never really fixed the problem...it was the camber. you could adjust the toe a little bit to help but never fixed it
coupleGs
Road noises in a G35 is normal.
But highspeed noises are usualy the tires or seats.
