Yes, bright red clear. No burnt smell at all. I dropped the pan and changed the strainer about 18,000 miles ago.Towncivilian wrote:Is the fluid clear, bright red? Does it smell burnt at all? Have you ever done a transmission pan drop & filter change? How have you maintained the fluid exactly?
As for P0400, have you checked if the vacuum hose for the <a href="http://motors.shop.ebay.com/Car-Truck-P ... =EGR+Valve" rel="nofollow" title="Link added by VigLink" class="vglnk"><span>EGR </span><span>valve</span></a> is clogged or otherwise damaged? Have you ever cleaned the <a href="http://motors.shop.ebay.com/Car-Truck-P ... =EGR+Valve" rel="nofollow" title="Link added by VigLink" class="vglnk"><span>EGR </span><span>valve</span></a>?
I checked for TSBs for both this shift issue and your P0400 code but found nothing relevant.
