RJ's engine rebuild and 5 speed swap, 56k?
YOUNG240SX
Car: 90 hatch
wtf?the tool broke?wow but I was think of having a shop do the swap,cuz I dont the best luck swap stuff when I did alone.almone meaning no one with the knowledge how to pull this bearing out.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
yea the tool i used didnt work for me, it worked for some though. the way i did it was a chisel and hammering it out. it came out slowly. when i had enough space to put the vice grips on it, i yanked it. i fell on my *** but it sure felt great lol'
if your not strong enough to pull it out, you can always tie the grips to the back of a car and pull it that way..... givin the motor is outta the car
94_240sx
Car: 94_240SX
Air tool with a chizzle at the end is your best bet. If you don't have an air tool, just use a hammer.
Hit it in different directions like this, and it'll come out easy. Took less than a minute to take mine out.
Eikon
Car: 71 240z, 93 Supra TT
The air chisel will work nicely!
Still without air tools, it's very easy:Get a nice sharp flat-head screw driver and a hammer and just cut it into pieces. They are made from very soft metal and the screw driver will cut through it very easily. Make three cuts through it and the pieces will pop right out.
Danrc30
Car: 93 Nissan 240SX convertible
81 Nissan 280ZX-T
85 Nissan 300ZX-T
I also struggled with getting that bushing out using the factory tool I borrowed from Nissan. I just didn't work. However, I found an easy way to remove the bushing. Take a very small drill bit and drill straight into the bushing 2 or 3 times right next to each other. The drilling creates a "swiss-cheese" effect. Then you take a good set of vise grips and clamp on that sucker so it will collapse and pull right out without effort. You may have to drill the exact opposite side as well to give flexibility, but I don't think I had to do that. All you really need is a good sharp drill bit and a steady hand.
Just a tip for the next guy that's doing it.
YOUNG240SX
Car: 90 hatch
thankz.im goin to try all of them.
