0wn3r »
https://forums.nicoclub.com/0wn3r-u31799.html
Fri Nov 02, 2007 7:03 am
Even though the NICO search engine is not optimal IMO, try google. This will keep you from getting flamed.
I found a few helpful sites that mention 10psi is a good place to stop at with a mostly stock setup using the T25. The FMIC upgrade seems to be the first step many people did. With the ceramic, 14-15psi supposedly starts to cause alot of wear from the heat. From there, probably injectors.
I'll probably try to stick to about 10psi using the T28. (Assuming I actually GET an engine...long story).
Search around, you'll find some more stuff and probably the same stuff I came across. I still say doing a tune always seems to be a good idea. It may cost a bit, but it's better to be safe than sorry.
