Thanks everyone for your condolences and comments. I came out of mourning yesterday afternoon long enough to pull the active sway bar, Jeff Williams FSTB and NICO ECU. Go away vultures.....They'll all be installed on the 90Q. I couldn't work up the nerve to start parting her out and the one time I thought about it and reached for a 12mm wrench my entire arm started shaking uncontrolably.
I'm reluctant to put in the time, effort and storage space needed to part this car out and can't afford a professional repair or engine replacement at the moment. It's probably going to be listed soon on Craigslist for dirt cheap just of get it out of my driveway. Any NICOnauts close by (or far away) who want to take this on? Any tax people know the latest laws on donating to a non-profit?
Q45denver wrote:However, 160K + miles is pretty good for a high performance engine. Keep/part any new/good parts and look for a low mile replacement.
It wasn't long ago that if a car had 100k miles it was ready for the junkyard. I'm always impressed by the high mileage most of us have on our engines . I had a 90 Dodge caravan that was a bucket of bolts at 80k miles and died at 130k miles. My 90Q has 245k miles and runs like new.
Mint Q45A wrote:You mentioned that you finally got the transmission to shift properly. Out of curiosity, what did you do to it? ....assuming you didn't simply replace it.......
transmission shifted great but it randomly would not shift out of 1st gear. I replaced the revolution sensor (ohming way high) and it shifts like new. It helps that in the last 4 years I've done two transmission flushes and drained and refilled the Mobil 1 ATF multiple times.
3Q Jay wrote:damn Mike--so sorry to hear.do you have your old oil? might be worth sending to blackstone for an analysis....you've never taken your balancer off (270 lb-ft on crank bolt) right?
Oops. Blended with used transmission fluid into two gallon containers. I've never touched the balancer or crank pulley. Except for the knocking the engine is still idling very smooth.
