well first off, i already have a co
ks13 wrote:your running a chrome upper ring also Tim?
that makes two of us.....high five. Strongest ring available, also the hardest to properly seat.
OP, if your not planning on a metal HG, why deck the block? If you havent spun any bearings, why turn the crank? And lastly, there are numbers on your crank and block than can be added together in order to obtain factory grade bearings and in turn factory spec clearances.
Nissan took the time to stamp the numbers, and make like 5 different grade std size bearings. Take this into consideration when pricing nissan bearings.
well first off, i already have a cometic HG with arp studs.
and im not going to pull rods, and pistons and use the same bearings that were in it, its called preventative maint. i dont want to have the motor aprt again, why not do all new bearings, with freah surfaces and cleaned/honed/decked block.
