Ring of light around low beam
ophdeheeezy
Hi
I searched but couldn't find the info. I recently purchased an 07 M35X and noticed I don't have that ring of light around my low beam. All pics I've seen of other M35s with their headlights on show a broken up ring of light around the low beam. I'm just wondering if there's a difference in headlight housings between M35s other than black housing and chrome housing. Or is there a bulb lighting up the area around the low beam?
Ilya
I'm not sure what you are talking about. Please provide a picture?
There is no ring of light on our car (I also have an 07 M35x).
ophdeheeezy
Found this pic. The light coming from that plastic shroud around the low beam. Mine doesn't light up like this. My buddy's 07 M35 has this piece lit up as well.
Brian35XR
Car: 2011 Infiniti M37x
2006 Infiniti M35x
2004 Infiniti G35 - Sold
ophdeheeezy wrote:Image
Maybe yours was painted by the previous owner as that shroud tends to turn greenish yellow as it oxidizes and its kinda ugly. What color is it?
ophdeheeezy
It still looks clear. I ask because there is absolutely no light coming from that piece. Which bulb is used to light up that piece anyways? My car came stock with halogens which I then installed HIDs and I'm wondering if that's the reason why it's not lighting up.
Ilya
I definitely don't have that in my headlight.
ophdeheeezy
IlyaKol wrote:I definitely don't have that in my headlight.
So I'm assuming there are differences in headlight between the M bodies besides HID vs Halogen and Black housing vs Chrome housing.
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
I have them. I believe they come stock with hid only and there is no specific bulb for it, it's just the main low beam shining through those "cut outs".
Ilya
TDot is probably right. My car was non-HID and I made it HID.
Larz
Car: 2019 Q70-L RWD
To my knowledge, that type of housing came with the AFS "adaptive front lighting system" package which was included in one of those pricey option packages - the low-beam bulbs pivot into turns while driving. Look next to your mirror adjustment buttons, You should see a switch that says: AFS ON/OFF. If you con't have this button, you don't have that package on your vehicle and your headlamp housing will look different.
Six_Legs
Car: 2007 Infiniti M45 Sport
1995 Nissan 240SX SE 5spd
I have em and I do have the AFS... :naughty:
