AltCoupe10 wrote:1. I was wondering if you were to remove your stock wheels/rims and replace them with larger ones, does that shorten the life on the wheel it sits in?
2. Or what if you were to get the same sized rims as the ones that comes with the car, do you have to necessarily replace the tire too?
3. What are some recommended brands when it comes to rims? I'm looking for some black 5 spoke rims for a blue coupe in the future. Thanks.
1. No, but the diameter of the wheel and width will affect your turning radius a bit (width) and odometer reading (diameter). I would check out some tire calculators to see what size wheel and tire, from stock, will minutely or drastically change your mileage reading.
http://www.miata.net/garage/tirecalc.html
2. If the rims you get are the same size as stock, you should be able to just swap the tires over. ButI would just wait till the tires die and get new tires on the new rims.
3. IMO, Nismo had some I liked, but expensive. I went for some 350Z rims instead. the Touring V.2's.
