BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Fri Jun 04, 2004 3:59 pm
This question is pretty vague, and I will have to give a pretty vague answer.
Wheel size and more importantly, tire size is all a matter of preference for each driver. Some people like a wide wheel with a super stretched tire, and others like a good fitting tire or mild stretch. You just kinda have to try things out on your own. I'm running on S14 SE's on my S13 (16x6.5 +40) with a slightly bulging 205/55/16 on them, and I can drift better than people with better tires, wider tires, wider wheels, etc. Wheel and tire size affects your turn in, catch, exits.. if you like hard turn in, soft turn in, you have to toy with settings. I've seen a 195 tire stretched onto a 10 inch wheel. Ridiculous, but SUPER STIFF.
The popular thing wheel-wise right now, is light, cheap, wide, low offset. 5chicken FN01RC's fit the bill perfectly. Dirt cheap, (around 800 a set before shipping), up to 10 inches wide, up 10 18 inches tall, with offsets as low as +12.
Junkyard wheels are always popular, junkyard mesh.
If you are experienced enough to start seeing what kind of style you have or even better, whos style you are closest too, I might be able to give you a better idea of what you might want to try. Also, your motor will come into play when choosing a wheel size, and again more importantly, a tire size. If you have KA, don't expect to be making big smoky drifts with a 245 in the back. If you haev SR or RB, don't expect to have much control over your slides on a 195 tire. Though I do rather well with a 205... I still don't have the steadiness I would like.
My setup, I like a softer turn in. I have 17x9 +15 FN01RC's and I'm going to try to find a 225/45 or 225/40 to put on it. Mild stretch, but not so overly stiff that I'll push going into turns.
