brianw wrote:Yes.
Factory offset for the 95-`03 Maxima (not sure about the 04+, but it's probably the same) is +40mm or +45mm for all of the wheels offered, which is well within safe range. (+35mm is about ideal for a more aggressive fit)
3rd gens (89-94) like a little less offset, +30mm is about perfect for 'em, but the factory wheels cross-fit over to later generations just fine. I forget the actual factory offset but it may be similar to the later generations as well.
This is very good information . I've recently picked up a 93 Maxima and according to Tirerack the offset is low to "0", which I couldn't believe or didn't want to believe.
Now all the existing Nissan/Infiniti OEM wheels are possible fits .
