compression »
https://forums.nicoclub.com/compression-u9345.html
Mon May 26, 2003 12:05 pm
The wheels on Tod's orange cars are custom made in japan by a company called Chevlon, I believe. Dont plan on buying them because you cant afford them and you dont know the right people.Wheels for a 510 are hard to find. The bolt pattern is 4 on 4.5" or 114.3mm. If you want a 7" wide rim, then you need a +23mm offset. It is easier to find +25mm offset wheels and use a small spacer to exactly locate the wheel. If you want an 8.5" rim, then you want a 35mm offset, and you shouldnt need a spacer. Nobody makes a 16x8.5 rim, (they are very rare) in a 4 lug pattern. Even if you do find one, it will be extremely difficult to find the right sized tire.I recommend using a 16x7 rim on all four corners and using 225 40-16 on the rear and 205 45 16 on the front.good luck to ya.You can also get a set of panasports....they have 510 specific rims that look nice.
