Darius »
https://forums.nicoclub.com/darius-u5470.html
Mon Nov 21, 2005 6:54 am
I don't think the wheels will fit on your car especially if you have coilovers. You are bringing the wheel 33mm closer to the strut and coilovers have a considerably larger diameter than stock struts. 9.5" up front is pretty wide, but ultimately if you want to know if they'll fit with your current setup, you'll just have to get under there and measure your clearances. May have to add a spacer or do some fender rolling/pulling.
As chmercer once said, "put wheels on car, drive around, look at sidewall, if rubbing, put spacer. good sized wheels will have ample strut clearance anyway."
