I currently run the XXR Type006 in 18x8.5 but what you need to look out for is the offset. 20x10 is very aggressive but Im pretty sure they only come in a +35 offset which will stick out a lot. If the the 19s are the same offset you should be good.cisco_24 wrote:ok so i just got a set of xxr006 rims for my altima coupe i got 19x.8.5 for the front n 20x10. can anybody tell me if they would fit good in my car n wat size tires would be better for my car i got a altima coupe 2.5. i would really apreciate ur help am new to this
so u telling me that the +35 offset is gonna stick out a lot? i dnt want them to stick out to muchdangeris wrote:I currently run the XXR Type006 in 18x8.5 but what you need to look out for is the offset. 20x10 is very aggressive but Im pretty sure they only come in a +35 offset which will stick out a lot. If the the 19s are the same offset you should be good.cisco_24 wrote:ok so i just got a set of xxr006 rims for my altima coupe i got 19x.8.5 for the front n 20x10. can anybody tell me if they would fit good in my car n wat size tires would be better for my car i got a altima coupe 2.5. i would really apreciate ur help am new to this
