Rims Interchange
1997i30
Maybe Maxhopper97 (Scott) knows, but is a 2006 G35 17x 7 rims able to fit on to a 1997 i30 no issues? Thanks
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
you're talking about the 6 spoke or 7 spoke? well, regardless, they'll fit. just look on the inside of the rim to see if they are marked front and rear. if so, make sure the tires go on the right wheels (for the directional tires). then, make sure the tire shop puts them in the right spot as well.
1997i30
They are the 6 spoke..I actually like the 7 spoke better..how do you think the 6 spoke would look on a 97 i30? I'm thinking the 6spoke would atleast look better than the stock 15" fan wheels....Thanks for the info, atleast I know they will fit with no probs.
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
they will look great. my friend has them on his 98 max and they are sweet. i just spent 15 minutes looking for a pic of his car, and i cant seem to find one. sorry man, but do it to it. it will look great.
1997i30
Big Thanks for the advice and opinion. I did a little research and these are staggered sizes? the fronts are different from the rear? Fronts 17x7.5 and rear is 17x8? will that throw off the fitment a little? This is only from the G35 coupe...if it's from the G35 sedan than it's just straight 17x7 all around? I plan to buy the rims tomorrow, but this will be a straight buy and I will not be able to mount the rims on my car or return them later. They just told me that it's off an 06' g35 and used only for 3 months tops with the factory potenza tires.
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
now that you mention that, they are staggard. but it will be ok. you juat have to remember that when you take it to get tires rotated. (if tires are same size all around, should be 225/40ZR18) if so, just tell them they have to dismount, rotate, then mount and balance again.
Rex
Car: None
Are these wheels off a coupe or a sedan?
If a sedan, they'll all be the same size and the offset will be a bit higher, but not high enough to be an issue.
If off a coupe, they'll be staggered (though you could run the same size tires on all 4 if you want) and the offset will be a bit lower. WHich should help bring the wheels/tires out to be "more flush" with the wheel well openings.
1997i30
The guy couldnt meet today, but he said it was off a coupe and the 6 spokes are not staggered because it's off from a base model. Does that sound right?..thanks
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
i was under the impression that coupes came staggard regardless, and sedans were not. not so sure.
Rex
Car: None
jltibbs wrote:i was under the impression that coupes came staggard regardless, and sedans were not. not so sure.
Same here ... except for the 18" G35 coupe, which had staggered tires even though the wheels were all the same width?!?!?
maxhopper
Car: 02 Maxima SE 6spd
I have to go with these guy's advise, they know what they are talking about.
