I did the math in another forum. With 8.5" wheels, on a +35 offset and 245mm tires, your tire will stick out 3.45" away from the mounting hub... the stock wheel/tires combo sticks out 2.46" from the mounting hub. This is about a full inch further out! If you drop 1", when you go over bumps, I'm almost positive your back tires will rub. Go out and look at your rear tire... then measure out an inch further, and factor in an inch drop... you'll have almost no travel room between the fender and your tire!generic808 wrote:Go with Eibach Pro-Kit springs to minimize the chances of rubbing. It's only a 1" drop so you'll probably clear.
It is a moot point if I was discussing fender distances. I was simply stating that 245-width tires are used via Nissan on rims that are <8.5" wide, thus the OP will have no issues using them on 8.5" rims.rjdmmfl1 wrote:Audatious, do you know if the fender distance (height and width)is the same on the 6th gen maxima and 4th gen Altima? If not, then that's kind of a moot point.
We should search and start gathering that information into a chart of some sorts......People are now starting to upgrade the factory rims so it would be helpful to knowgeneric808 wrote:I believe there once was a sticky with wheels/offsets listed, but it disappeared! I don't think many people were contributing to that thread so Tyler axed it.
Yes, but the thing is, he never asked if 245's would fit on an 8.5" rim, he asked if the entire setup would fit on the Altima. That remains to be seen with a 1" drop. And after looking at the rear tires of a car with similar diamter tires, and the exact same rim width, tire width, and offset, the answer is NO if you want to safely go over bumps with no rubbing!audtatious wrote:
It's all good , just don't wield your moderator sword at meaudtatious wrote:You are correct, it was actually Eric that made a comment about 245's on a 8.5" rim. Of course, reading it again his comment was probably more towards the offset than the actual tire width on the rim.
I will STFU now and go hide
Very good point on rolling the fenders, not sure who would want to do that to their baby thoughzenki07 wrote:true...setup shouldn't rub...if it does w/ the drop...he can either compensate by adjusting the toe and camber...if not...roll the rear fender a bit...problem solved.
I know there's people that rather not roll their fenders, but sometimes you gotta do it when going with a cast wheel that is manufactured to fit a bunch of vehicles with similar offsets.
Yeah, I was talking about the overall setup with the tires and offset. I meant the tire width in relation to rubbing, not the wheel/tire fitment.audtatious wrote:You are correct, it was actually Eric that made a comment about 245's on a 8.5" rim. Of course, reading it again his comment was probably more towards the offset than the actual tire width on the rim.
