Rims for s14
EckOMaN2k
does anyone happen to have any pics of the emerald blue 240sx well a s14 with gold rims? Oh yeah will 17's on a s14 with a 2 inch drop look good you think because im trying to feel up the gap in my car. Also ummm is a 40+ or a 42+ offset be good enough to ride on?
Bryants95240sx
the stock offset is 40 i woildnt go any higher or your gonna sink your wheels. maybe like a 35 to 25 offset sounds good
offtheline
I personally would not buy +40 or +42 offset wheels. To me its just wasting money on wheels that will still look sunk in as the stock wheels already do.
With a 2 inch drop, 17's will look very nice. You pretty much will completely eliminate wheel gap.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
one thing you can look into are good wheel spacers w/ longer studs...saying that you cant quite afford good offset wheels...but htose spacers will cost you about $210 for all 4 wheels...:(
just food for thought
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
Where are you buying your spacers from, cause they've gotta be made out of gold or something. Must suck to live in NoVA;).
BoyWonder
Car: '93 Nissan 240SX S13 Convertible (reclaimed... wootles)
[ZERO-S] wrote:Where are you buying your spacers from, cause they've gotta be made out of gold or something. Must suck to live in NoVA;).
As if Newport News is the Gem of Virginia :D
JayPat83
i have 18x8 with a +17 mm offset all the way around and they look grrrrreat. got tired of seeing those damn sunk in wheels!
MainEvent212
haha, well all the good ones i know of... H&R spacesr are 96 a pair thru options auto...which is the only place i've found them...and touge factory ones are 105 or so...those are nice cuz they're adjustable
JayPat83
25 mm H&R DRM Spacers thru Options are 120 a set and they just bolt on to your factory studs and come with four new studs already installed in the spacer. that is really what i have.
MainEvent212
yeah, that's what i plan to get...except only 15mm spacers, which i think come w/ new studs to press into the stock hubs
JayPat83
anything under 25 comes with press in studs if they are made by H&R. now i have heard that Eibach has came out with some that are similar but they are too new for me to trust. and you can't say that spacers are gay cause do you know how many of those awesome offsets the popular drifters have are because of large spacers?
MainEvent212
lol yeah, like 40mm spacers and stuff!
JayPat83
oh yeah with a 13 inch wide rim!
coupe4me
Car: '89 240sx coupe and '02 Sentra Se-r V spec
Question, I have a s13 and am about to do the 5 lug conversion with SE wheels. I would like to get spacers for this set up and just dont know enough about this. could a couple people give me their opinion, please. I would like them to be further out but not too far. Thanks
JayPat83
i think the SE wheels have a 40 mm offset so a set of 10 mm spacers would make it look decent and would clear all coilovers and Z brakes.
Dystopia
Car: Nissan S13
if you re just going to run stock se wheels i would run a huge sopace and get it as close to 0 offset as posible. 15x7 wiha 0 offset is nice negitive is even better
MainEvent212
what? the stock rims are 7" wide w/ +40 offset...you're rying to say that they need to be pushed out to the fenders 4cm? if not more?
that's a bit overkill dude...they're only sunken in about 4cm...and if you're anywhere near the fenders w/ your tires...you dont want them to scrub...cuz that's never good... i guess if you've got rolled fenders, or a suspension that sits high enough in the rear ( i dont think mine does) then i guess you'd be alright...but i would think maybe 25-30mm spacers would be about all you'd wanna use...
JayPat83
no more than a 30 mm spacer. thats what i am using.
MainEvent212
well i just ordered those tougefactory adjustable spacers...hopefully those will work out nicely
JayPat83
that is what i have and you will be completely satisfied i am sure.
JayPat83
a totally genius idea!
Dystopia
Car: Nissan S13
MainEvent212 wrote:what? the stock rims are 7" wide w/ +40 offset...you're rying to say that they need to be pushed out to the fenders 4cm? if not more?
the stock ones are nowhere near flush and they are 6.5 stock.
personally next wheels i get will be 17x9 with anywhere from a 0 to a +20 offset closer to 0 is better
barrigas14
17x9 all around using a +22 offset. 8" is the least i would go with.
