Rims for my KA24E
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
I was looking at this set of Rims for my KA24E (lol I just add the engine so it does not seem like i'm posting in the wrong forum ) 4 14" X 6" SILVER FINISH PROLINE RIMS CU55
OFFSET: 38
BOLT PATTERN: 5 X 100/5 X 114.3
BACKSPACE: 5
Will these work on a 89 240SX? the seller has it listed that they work with S14s Did Nissan change the bolt pattern from the s13-s14?
Thanks!
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
Ah crap the 95-96 S14 has a different pattern the set of all 4 rims is only like $60 on ebay right now and it ends in a day.. don't think it will go to much higher.
http://cgi.ebay.com/ebaymotors...%3AIT anyone need rims? lol
240marcuSX
Car: E34 525i
E46 M3
your bolt pattern is 4x114.3, and why not post these types of things in the correct forum?(the suspension forum)
All_Motor_KA
Car: 1989 240sx SE
Isn't there a sticky for rims???
240DRFT
get some bigger than 14's...do you only post in the ka forum? lol
tiger
personally, I think the best offsets for the s13 are
25 mm in the front35 mm in the rear
14's would look really stupid by the way.... 14's go on Kei cars, not 240's.
do you realize how small that is?
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
I know a guy with 14's on a Civic hatch, and they look ridiculously small even on that.
I think my big wheel had a 14 up front.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
What size rim do you think I should get? stock is 15 right?
240marcuSX
Car: E34 525i
E46 M3
stock is 15", theres nothing wrong with running a 14" wheel if thats what you want to do.
id rather run a 14" than a 17", but thats just me, its more about tire compound than tire diameter.
tiger
16's or 17's... i have seen 18's on a 180 and they look bad ***... the mesh style rims. But I think tires are more expensive for 18's. But 16's will look sorta stupid if you don't have suspension (that's just my opinion) especially if you get low profile tires then the gap between your fender and tire will be huge and it make the wheels look oh so smaller. I say go with some 17's. It just depends on what you are going for... performance or style. If you go 18... that's more style. I have 17's because it's in the middle.
240marcuSX
Car: E34 525i
E46 M3
16" wheels are probably the overall best sized wheels imo, save weight, $$ on tires, better sizes than stock. the only compromise would be appearance when compared to a bigger wheel.
but like i said before, id rather my wheels look to small than feel to big.
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
You do *not* want 6" wide wheels on your S13 dude...
If you're really on about running 14's, you can do it, but they need to be a helluva lot wider than that. I dunno how wide exactly the Konig Rewinds are, but something like that might work, with big, fat rubber. How about some smaller circle racing wheels, like what DeviousKA runs? Or diamond racing?
You could also pick up some smaller, used JDM wheels from ebay, or rbmotoring, or takumi project. Some SSR MK2R's, Wats, Hayashis, Southern Ways Meshies, etc...
And +38 offset = t3h poo. I think the rewinds come in zero offset.
Veriest1
Car: '96 BMW M3
'93 Nissan 240SX coupe dd
14's should clear the stock brakes fine, don't wiegh anything, forged aluminum is cheap in 14" sizes, and have incredably cheap high quality tires available. Sounds like a plan.
15" isn't bad either.
